Discussion topic: Slow WiFi speed
Message posted on 01 Apr 2025 08:36 PM
Slow WiFi speed
I am paying for 900mbs speeds, I'm lucky if I'm getting 70. Also, we get no wifi in any bedrooms upstairs, only downstairs (where the router is) and even then it's slow.
Message posted on 02 Apr 2025 08:10 AM
Re: Slow WiFi speed
@BeckyM1 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
