Discussion topic: Slow WiFi in one room
This message was authored by: VIP+app+links+bro
Message posted on 23 Jul 2026 06:37 PM
Hi, with the new sky max router and pod upstairs I have 300 to 400mbps everywhere except in the kitchen where it's consistently below 8mbps.
Find out more
Message posted on 23 Jul 2026 07:28 PM
Re: Slow WiFi in one room
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
