Discussion topic: Slow WiFi and drops out
This message was authored by: Sar1701
I have tested the Broadband as per the App but it is intermittently slow especially on mobile devices and drops out regularly. What can be the issue? Thanks
Re: Slow WiFi and drops out
@Sar1701 if younpost your hub's connection stats forum members maybe able to advise otherwise we are guessing. See Find your Sky Broadband router statistics
Avatar for Sar1701
@Chrisee do you mean this? Speed to Hub 50.4 Mb, upload speed 9.6 Mb, data usage 4.54GB. Tia
@Sar1701 no we need to see the stats page from the hub as explained in the link.
Avatar for Sar1701
Router Statistics
System Up Time: 28:46:38
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 2945545 7692769 0 38740 73206 28:44:29 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 2111951 804800 0 15326 12619 28:44:47 WLAN (5 GHz) Up 6702953 2529284 0 0 16952 28:44:46
Broadband Link Downstream Upstream Connection Speed 60211 kbps 10064 kbps Line Attenuation D1(15.5 dB) , D2(42.8 dB) , D3(65.0 dB) U0(6.9 dB) , U1(34.8 dB) , U2(52.7 dB) Noise Margin 2.9 dB 6.0 dB
Poll Interval:
Seconds (at least 3s):
Avatar for Sar1701
@Chrisee @Any thoughts?
@Sar1701
Your stats show a good connection with no faults. Your WAN has not dropped either so the line is stable.
I suspect your problem is WiFi congestion, have you looked at Sky's WiFi help guide below?
I am NOT a Sky Employee
Avatar for Sar1701
@jamesn123 many thanks
This message was authored by: Cheryl1232
Re: hi - my WiFi is very slow Slow WiFi and drops out
Status of your broadband and WiFi network
Broadband Connected
WiFi Enabled
WiFi Network Name (SSID) SKY9Z4EN
WiFi Network Visible Yes
Current WiFi Channel 1 (2.4 GHz), 36 (5 GHz)
WiFi Encryption WPA2-PSK (2.4 GHz), Mixed WPA2/WPA-PSK (5 GHz)
VoiceConnected
My wifi is really slow and drops out - above stats
