Discussion topic: Slow Internet connection
This message was authored by: GregG1990
Hi - I recently upgraded my broadband to sky fibre 150. However, I am finding issues since moving to the new broadband when accessing apps, waiting for Internet pages to load, videos on apps take a few minutes to load. I end up just switching my WiFi off and using my data roaming instead which then opens all these up instantly. Having upgraded my broadband, I would have thought all these things would be quicker than the slower broadband I had previously which worked no problem. Does anyone have any tips on how I fix this? Thanks in advance
Re: Slow Internet connection
@GregG1990 Would have helped with a little more detail from you, when FF was installed, is the sky Hub stiil the same as before, and did it also move from position by much or still exactly the same, what sky Hub are you using....
FF500 for me on the SR203 rocked at full speed with no issues, did have to set the Broadband Shield but i also went and switched the wanoe interface as got a refurbed unit for the Mar2025 return to sky! All the sky units retired and back in there boxes though!
