Discussion topic: Slow Fibre internet
Message posted on 01 Jul 2025 09:59 PM
Slow Fibre internet
Can someone please help me 🙂
My fibre 1000mbs is soo slow that even netflix buffers..
I have the 1gb package and had it now for about 6-8 months so assuming its now settled i was expecting better i suppose...
If i look at the router settings they all look ok, even the SKY Service Checker tells me I am getting over 600mbs but... I fi run ANY online speed checker they ALL say about 90-100mbs, although often say alot less...
My speed checks are done with my PC and/or with my LAPTOP connected via cat6 ethernet cables and with WIFI turned of, So there is only ever one device connected whilst i speed test..
I have not phones SKY as of yet because all they will say is you have too much connected...
here is a dump of info that maybe helpful 🤔
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 1510803 1682833 0 260641 5660703 00:27:37 LAN Up 823502 1397320 0 1129829 121764 00:29:38 WLAN (2.4 GHz) Up 39920 15542 0 24976 7095 00:07:14 WLAN (5 GHz) Up 1019431 91755 0 8955683 158950 00:06:18
Message posted on 02 Jul 2025 11:03 AM
Re: Slow Fibre internet
@martin_nextdoor What is the Interface NIC in the PC and the Laptop, have a look at the properties on each and make sure the sync is 1000/1000 for the values, One bad connection on the cable will bring those down to 100/100 or if you have set the hub for Fast Ethernet or using a Fast Switch those are only rated for 100Mb/s speeds!
