Discussion topic: Sky wireless names
This message was authored by: Bob0402
Sky wireless names
What is the difference between skywireless names :
Skyjnjtp and Skycw3za.
Re: Sky wireless names
@Bob0402
Only one of those names will be your Wifi network as there other is probably one nearby to you so if you look on your broadband hub it should tell you what one is yours as there should be a label on it with these details on.
