Discussion topic: Sky wiifi box
This message was authored by: 1jaggers1
Sky wiifi box
I do not like the black sky wifi box ....can I change it to a white box?
Re: Sky wiifi box
@1jaggers1 Yes that is no problem sky will upgrade you equipment, with any appropriate charges that need applied, you will have to call them though to get it done, or see if you can upgrade online via the sky.com web site! There may be a current stock issue with the white Sky Max hubs just so you are aware.
