Discussion topic: Sky wifi max
Message posted on 29 Dec 2024 10:06 PM
Sky wifi max
We have streaming tv . Two pucks and 3 Xbox and 1 pc and 3 smart tv connected to wifi when I move the sky wifi booster to each room it works but then drops out of other rooms . Is it possible to have more sky max wifi boosts that plug in ?
Message posted on 30 Dec 2024 06:19 AM
Re: Sky wifi max
@matt+today the pod extender should not be moved around it should be installed roughly half way between the hub and where you need the boost often on a landing or in a hall. Sky will supply up to 2 further pods after a visit from an engineer who will advise what is required if you cannot get the guranteed speed in every room with a single pod. See https://www.sky.com/help/articles/sky-wifi-max
Message posted on 30 Dec 2024 09:53 AM
Re: Sky wifi max
It's not been moved around only for testing purposes it stays in one location but when everyone is online the sky glass tv and puck struggle starts loosing connection and spinning the circle icon and sometimes switches off
