Discussion topic: Sky wifi max
This message was authored by: howdy12
Sky wifi max
Just received my sky wifi max hub, connected it all up and working etc, but bit confused as there seems 2 different identifications on there, I mean the hard wired line to the hub for e.g my sky q says connected too skyd9@## when my wifi devices are connected to sky4f#@# which is the correct one as that's the I.d on the card that came with it. So my question is why is it different on the sky q🤔.  Also if try to connect my phone to the skyd9 it fails straight away only the sky4f works. Hope there's a simple answer to this.
Re: Sky wifi max
@howdy12 ignore the SSID your Sky Q box reports that is a closed network the Q boxes use to communicate the SSID onnthe hub's label is the onne to use for thitd party devices.
Avatar for howdy12
Level 4 icon
Re: Sky wifi max
Cheers for that, makes sense now. Sky q be going on Wednesday anyway, got sky glass coming.
