Discussion topic: Sky super fast router (white box)
This message was authored by: Garyc4
I have just changed my router from a black router to a white router which is to increase my speed, now my Tspo cameras will not connect to the router. Any ideas how to correct this please
Re: Sky super fast router (white box)
@Garyc4 Take a look at the link below, either the wireless securities or the temp disable a band to connect! Would have been ideal if you had changed the ssid/password to match that off the old sky Hub, but you are probably too far down the line now!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
As for speed, hub for hub just may not do it for you, so keep that in mind!
Hi @Garyc4
You will need to either switch the authentication mode from WPA3 to WPA2 or temporarily disable the 5ghz band in order to connect your smart devices.
I am NOT a Sky Employee
