Discussion topic: Sky signal issue
This message was authored by: Deminpd
Sky signal issue
Why doesnt my sky work in early hours of the morning?
Re: Sky signal issue
@Deminpd not a broadband issue but most likely cause is the box is set to the eco standby setting change thst to Active or None and a main box should work with Q minis make sure you check the main Q box as well.
