Discussion topic: Sky router
Message posted on 13 May 2026 07:09 AM
Sky router
Sky broadband is down, orange light on voice reset 4 times but still the same
Message posted on 13 May 2026 07:30 AM
Re: Sky router
@Abbie69
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
