		Discussion topic: Sky router
	This message was authored by: alma5cosy
		Message posted on 29 Jun 2025 09:09 AM
							Sky router
I have an old sky router, should I return it?
		Message posted on 29 Jun 2025 09:17 AM
							Re: Sky router
@alma5cosy Which one take a look at the link if you are not sure! If it is the Sky hub or the Sky Q then more than likely NO sky do not want it back!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
