Discussion topic: Sky router models
This message was authored by: Lucyliu2
Sky router models
I know that the latest sky router, white, is the SR213 and the previous, black model is the SR203.
But I keep seeing references to "Q hub" and "4.2 hub", are these different models or same models with different names?
Can anyone clarify this?
Re: Sky router models
@Lucyliu2
The Q Hub (ER110/115) was the model launched in 2016 alongside the Q satellite television platform: it's now obsolete because it doesn't support Sky Talk Internet Calls (and also isn't compliant with updated UK security regulations for broadband routers so Sky is obliged to try and remove them from use)
 (images from this review a decade ago)
'4.2' is an internal designation for the 2019 Sky Broadband Hub (SR203/204) : I believe the Q Hub is designated as '3.0'
Avatar for Lucyliu2
Level 3 icon
Thank you Timmy, very helpful.
