Discussion topic: Sky router keeps disconnecting
Message posted on 18 Nov 2024 02:38 PM
Message posted on 19 Nov 2024 11:37 AM
Re: Sky router keeps disconnecting
The line test only checks for your hubs connection periodically so if your hub is only dropping for a matter of a min or two then the online test wont pick it up
Message posted on 21 Nov 2024 12:02 AM
Appreciate the reply but the issue here is that there is just too much latency on Sky.
If I try acccess a site, it takes longer than it should to access. If i switch off my wifi and use data, boom, the site loads and works instantly (thats on 3g and 3 bars). If i play online, there a lag every now and then.
The list can go on, but based on what ive seen on-line from others, this looks to be a common issue. The speed LOOKS good when you test it (70/125gb) but the there just too much of a delay ... Which is a shame, but ill be looking to switch providers once contract ends
