Discussion topic: Sky router issues
This message was authored by: DG43
Sky router issues
Router is only showing two green lights where as it's normally 4. The other two are amber, have done the switch off wait a minute and then reboot and no change?
Re: Sky router issues
@DG43
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
