Discussion topic: Sky q booster
This message was authored by: nickandsue
Message posted on 04 Aug 2024 11:59 AM
Sky q booster
I have a Sky Q wifi booster which is working fine connected to a BT hub. Will I still be able to use the booster if I change to a different broadband hub? Is the set up the same?
Find out more
Message posted on 09 Aug 2024 11:31 AM
Re: Sky q booster
A Sky Q booster will only work with a 3rd party broadband provider if you have Sky Q. If you change provider and ditch Sky Q it wont work, but if you keep Sky Q it should still work.
I am NOT a Sky Employee
