Discussion topic: Sky puk
This message was authored by: Peteh1979
Message posted on 01 Apr 2026 08:00 PM
Sky puk
Realy poor poor the signal from front room is bad would a sky booster help improve signal and WiFi to my bedroom
Find out more
Message posted on 01 Apr 2026 09:41 PM
Re: Sky puk
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
