Discussion topic: Sky puck issues
Message posted on
19 Aug 2024
10:40 PM
- last edited:
20 Aug 2024
08:48 AM
by
Kelsingra
Sky puck issues
I have a sky glass tv in the lounge connected to the internet. Today I put a Samsung tv up with a connected pug in the garden room. The Samsung tv would not connect because of poor internet signal. So I plugged in. TP booster and it now connects. Then after turning it off and back on again it now saying no connection. So I set up the tv again and it's saying wrong password but the password is defo correct. Tv in lounge still works but tv in garden room is saying wrong password. It's giving me two option for network settings. Option 1 which is they original network or optional 2 which is the original network that says extension. Do both tv have to be connected to the same network to function. Also I have to keep changing setting on my. iPhone. If I'm in the garden room I have to choose sky extension setting then when I come. Backed in the house up stairs I have to connect to sky original net work. I must be doing somethhirwng wrong. Please help!
Moderator note: Changed title to reflect topic more.
Message posted on 19 Aug 2024 11:50 PM - last edited: 19 Aug 2024 11:55 PM
Re: Sky puck
@Skyalc Your post is confusing are you saying your actual TVs won't connect to broadband or the stream puck?
From what I can gather this is neither a problem with Sky Glass or the stream puck so not sure why you posted in the Glass forum.
This seems to be an issue with your Samsung TV from your post.
