Discussion topic: Sky password
This message was authored by: MEAGAINSON
Sky password
I'm locked out of my Windows PC and Computer. I can't connect because of Sky Password not working... The message below it reads: Some information changed since you last connected. We need additional information to complete the connection. It doesn't say what information it needs though!
Re: Sky password
@MEAGAINSON bit confused here. What does your Windows PC have to do with your Sky password?
Re: Sky password
@MEAGAINSON
I have moved your post out of the Sky+ box forum as your issue is clealry nothing to do with this.
Is this a Sky wifi issue, if it is  Go to Settings > Network & Internet > Wi-Fi > Manage known networks. Click on your network and select Forget.
Avatar for MEAGAINSON
Re: Sky password
Where have you moved me to???
Re: Sky password
@MEAGAINSON
To the broadband forum on here for the reasons stated in my earlier post.
Have you managed to sort this now ?
Re: Sky password
No...... I keep going around in circles!!
Re: Sky password
On your PC @MEAGAINSON do you try this:
Then go back to Network & Internet > show available networks and when you see your one, select it and enter the password again.
Re: Sky password
Thank you so much for your help. Sonia
