Discussion topic: Sky not working
Message posted on 15 Apr 2026 04:28 PM
Sky not working
No internet no WiFi no sky tv
Message posted on 15 Apr 2026 04:39 PM
Re: Sky not working
@MP41
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 15 Apr 2026 08:24 PM
Re: Sky not working
My sky TV not working screen is blue and showing software error
