Discussion topic: Sky not working
This message was authored by: Julia62L
Sky not working
I need my sky to work
Re: Sky not working
@Julia62L
Presumably you're referring to your broadband?
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
