Discussion topic: Sky max
This message was authored by: Charlottetay83
Message posted on ‎23 Mar 2025 07:45 PM
Sky max
My sky max keeps dropping been on it for 2 months every week I have to ring up sky to get it fixed we have had 2 engines out now having another but I'm thinking of changing back to the old sky Internet
Find out more
Message posted on ‎24 Mar 2025 07:55 AM
Re: Sky max
@Charlottetay83 sorry you are having issue with your broadband. Issues can be hard to pin down but getting an engineer out is the best idea.
However it is very unlikely if you have moved from a partial fibre connection to full fibre that you can revert as Openreach simply wont allow that. There several other switches which are effectively one way only.
