Discussion topic: Sky max router with ps portal
Message posted on 27 Dec 2024 04:14 PM
Any advice using the ps portal on the sky max router people say change DNS settings to Google how is this changed on sky router?
Message posted on 27 Dec 2024 04:20 PM
Re: Sky max router with ps portal
@Fitz21 you cant change the DNS on any Sky hub those settings are hard wired. However if you want to use different DNS provider then edit the network settings on the device which will over ride the hub's settings.
Message posted on 27 Dec 2024 04:21 PM - last edited: 27 Dec 2024 04:21 PM
Google AI correctly reports that it's not possible to change DNS on a Sky Hub..
