Discussion topic: Sky max pod Ethernet socket
This message was authored by: Shandor
On the sky max pod, there are what look like two Ethernet sockets.
mare they usable and how to set them up.  No instructions received or so far, found online
Re: Sky max pod Ethernet socket
@Shandor
Both should work as wifi to ethernet bridges
Ie wifi from the hub and ethernet to a device
@Shandor
Or a pod can be on the end of an ethernet run from the router, or connected to ethernet cable from a Powerline network adapter. I imagine they may also act in a passthrough mode.
All of these should be automatically configured: pods are essentially not possible to administer separately.
This message was authored by: mrwwt
Does this mean if you plug it into a wifi socket that runs through your house, the Pod will use that more reliable connection instead of picking up and extended the original wi-fi signal?
WiFi doesn't have sockets.
If you mean an ethernet cable running back to the router, then yes.
