Discussion topic: Sky max issues
Message posted on 18 Feb 2025 08:35 PM
Sky max issues
Received sky max hub over 2weeks ago and it won't complete setup in sky app keep saying to wait 20mins then says there is an issue. After testing network speed seems less than the guaranteed minimum speed, and it says WiFi is turned off. WiFi is working on sky q box and mobiles although some devices won't connect ( tv upstairs and other devices).
Message posted on 19 Feb 2025 07:48 AM
Re: Sky max issues
@Andy903 if signing out and fully exiting the app and then restarting it doesnt clear the set up fault call Sky. The new hubs use a more advanced wifi security setting that some devices notably Samsung TVs cannot connect to. Once your My Sky app has been set up then go into the Advanced settings for the hub and change tge WiFi security from WPA3-T to WPA2.
The new hubs cannot use your Sky Q boxes as WiFi extenders as the old hubs did instead you may need a matched pod extender which Sky will send out if you ask as part of the WiFi Max bundle.
Message posted on 19 Feb 2025 08:50 PM
Re: Sky max issues
Thanks @Chrisee for your advice, I have signed out, deleted app, downloaded app again and still not working.
Message posted on 20 Feb 2025 07:52 AM
Re: Sky max issues
@Andy903 you need help from Sky so I am escalating your post to the Sky team who support the forum who should be in touch soon to offer you a private online chat session to get this sorted. Keep an eye on the forum as if you miss the message just click the brightly coloured chat icon which will be added to the forum pages for you to use.saving a long phone call.
Message posted on 20 Feb 2025 10:24 AM
Re: Sky max issues
Thanks for escalating this. We’ve sent Andy903 an invite to chat.
Lisa - Sky Tech Team Expert
