Discussion topic: Sky max hub
This message was authored by: Pault-07771
Message posted on 02 Jul 2025 10:09 PM
Sky max hub
Hi Just switched from my old sky hub to a sky max hub, now my cctv hard drive which is caonnected via ethernet cable is not working. Any ideas please
Find out more
Message posted on 03 Jul 2025 08:17 AM
Re: Sky max hub
@Pault-07771 check the set up of the drive as often these are set up to have a fixed IP address if so you need to reserve that address on your new hub using the My Sky app. If not a reboot of the drive may help.
