Discussion topic: Sky max hub light is red
This message was authored by: kenjo4
my new sky max hub light is straight to red and staying red. It should be white? Any ideas please?  Thankyou.
Re: Sky max hub light is red
@kenjo4
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Avatar for kenjo4
Thankyou for your help
