Discussion topic: Sky max hub ethernet upload speed problems
This message was authored by: MadmanP
Hi all. Noticed a problem with our Sky Max hub yesterday that I can't get to the bottom of.
We have 900mbps speed down and 100mbps up when on wifi and that work well.
What is a problem is the ethernet connections on the hub.
Download is great, upload is not so great - hitting a magnificient 2 - 5 mpbs on speed tests.
This is with one PC connected via any port on the hub and nothing else. Have tried numerous resets and different known good cat6 cables.
The mysky app says speeds are good and wifi works well as above, so I guess the ethernet ports have some sort of issue.
Trying to find somebody with this problem seems to be difficult - anybody any ideas or experienced the same?
thanks.
Re: Sky max hub ethernet upload speed problems
@MadmanP Have a look at the figures for the detail on the upload test once you have run it, you have NO control over speed once it leaves the Hub! The OR bias is way towards download on the Fibre!
https://speed.cloudflare.com/
