Discussion topic: Wifi Issues
This message was authored by: Jonathan1976
Wifi Issues
Wifi drops out no reason
Moderator Actions: Retitled to better refelct issue
This message was authored by: Fatmandan
Re: Sky is **bleep**e
Yup had the same issue, yet the app tells me everything is working perfectly fine.... obviously [removed] not literally no internet light on at all after I reset the router. It's been happening more and more over the past month or so
Moderator Actions: Removed inappropriate language
@Jonathan1976 see https://helpforum.sky.com/t5/Broadband/Important-Information-Scheduled-Broadband-Maintenance/td-p/51...
@Jonathan1976
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
This message was authored by: JMilton96
I've had issues saying the connection is good and nothings wrong, but my console and laptop won't load anything or boot up any apps and games, seems to work after a certain time in the evening though
