Discussion topic: Sky internet
This message was authored by: 1Wisdomkey
Sky internet
 My sky internet has randomly disconnected and wouldn't restart. Could you kindly assist
Re: Sky internet
@1Wisdomkey
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
