Discussion topic: Sky internet
Message posted on 19 Nov 2025 06:50 PM
Sky internet
Anyone's elese internet down
Message posted on 19 Nov 2025 06:55 PM
Re: Sky internet
I'm sure there is… somewhere in the UK or ROI.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Message posted on 19 Nov 2025 08:11 PM
Re: Sky internet
At any particular point in time there will be many thousands of individual Openreach circuit failures affecting Sky Broadband customers: that's just a product of having over five million subscription households.
