Discussion topic: Sky internet
Message posted on 05 Nov 2025 10:19 PM
Sky internet
Message posted on 06 Nov 2025 08:12 AM
Re: Sky internet
@Bunkie84 sounds like yourissue is poor WiFi signal levels in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
