This discussion topic has been answered Discussion topic: Sky hub
Message posted on 28 Mar 2026 05:57 PM
Can I set up my new sky hub after my activation date or dies it have to be done on that exact date?
Message posted on 28 Mar 2026 10:27 PM
@Janis2012 wrote:
Do you think it will be ok to do it after
the activation date
Yes.
Message posted on 28 Mar 2026 07:20 PM
Re: Sky hub
If you are with another supplier then you need to wait until the day of activation otherwise you will have no working broadband until the switch happens. If you are not currently with anybody then you are free to set it up whenever you want but it probably will not work until the actual activation day.
Message posted on 28 Mar 2026 07:24 PM
Re: Sky hub
Is it ok to activate a sky hub AFTER your activation date.
Message posted on 28 Mar 2026 07:52 PM
Re: Sky hub
It should be OK, are you joining Sky Fibre ?
Message posted on 28 Mar 2026 08:58 PM
Re: Sky hub
No just up dating the hub
Message posted on 28 Mar 2026 09:10 PM
Re: Sky hub
the activation date
the activation date
Yes.
