Discussion topic: Sky hub
This message was authored by: Mar1964
Sky hub
I need a master microlitre to connect the cable to the hub
Avatar for Mar1964
Level 0 icon
Re: Sky hub
I need a master micro filter to connect the cable to my hub , it's a old phone connected
Re: Sky hub
@Mar1964
You are not emailing Sky by posting in the email forum.
If it is a microfilter you need then you can order these online or pick them up from DIY shops.
