Discussion topic: Sky hub max
This message was authored by: Janeybel
Sky hub max
We have busy wifi household, 4 adults with 2 gamers. 3 streaming pucks etc etc etc. Would a sky hub max improve connectivity? Our speeds are OK, but wifi is not consistent quality, especially in the evenings.
Re: Sky hub max
@Janeybel it might help marginally but in all honestly if you are still on a copper conection I wouldn't bother. If you are on full fibre it makes more sense but with the usage you list I wouldn't bother Inwould be considering buying your own router with QOS which can prioritise gaming and streaming traffic Asus routers work well on Sky full fibre services BUT you lose the Sky landline.
