Discussion topic: Sky hub login barely possible?
This message was authored by: Jaywrk
Hi. I have a problem connecting to my sky hub to change settings. The login prompt just kicks you out every time you log in. This appears to be a common issue with the new hub. I have managed to get in once to change my Ssid and WiFi password. I have tried 3 phones my computer and laptop. The login prompt just comes straight back up. Very occasionally it shows the router page. But then selecting any option again kicks you back to the login prompt. This router is messed up. Any ideas or request a replacement?
Re: Sky hub login barely possible?
@Jaywrk
If that's the white Max Hub then it's intended to be administered through the My Sky app, not a browser connection.
There's also a known problem using Safari over WiFi for Hub administration of previous models.
Avatar for Jaywrk
Ok..well it's the black one. I assumed new as only just got it.
And I've tried several browsers on the pc and all do the same. Totally confused.
Avatar for Jaywrk
Says Model SR203.
@Jaywrk wrote:
Says Model SR203.
@Jaywrk so when you are tring to login to the router are you using
admin as the username
and
the wifi password (the second white label  down on the back of the router) as the password
Avatar for Jaywrk
Yes admin as login.
Although my WiFi password is now different as I managed to change it the 1 time it let me in.
But original WiFi pass doesn't work. Or new pass.
Don't want to reset it again and took me 3 hours to get in the thing before.
@Jaywrk
Are you trying to connect always via wifi, or have you tried ethernet on your pc or laptop if they
have such connection and if you have a cable.
Please also bare in mind that the router has 2 passwords.
1 for the SSID and also one for the Router Administration, so not sure which one you changed.
If you did not change the admin one then the label still applies.
Router reset option always changes back to this if you do the manual reset.
@Jaywrk
Also from the Password setting screen
Set Password
Use this page to change the password you use to access these pages.
This isn’t your My Sky password.
The new password must be 10 characters long, contain an upper case letter [A~Z], a lower case letter [a~z], and a number [0~9].
If you change the password and you have backed up the Sky Hub settings previously, you should do a new back up so that the file includes the new password.
For security, the Administrator's login to the Sky Hub will timeout after a period of inactivity. To change the login timeout period:
  • Type the value in the Administrator login times out after idle for field. The suggested default value is 5 minutes.
Avatar for Jaywrk
Yes I realise there are 2 passwords . One for WiFi and one to access the router. Same as my last one.
Ok so I'm managing to occasionally get the router to show the pages. But then again asks for the password again when you click any option. And still keeps popping up the logging prompt..sometimes with an insecure connection warning.
Let me try something........
Avatar for Jaywrk
Ok think i found the problem. Reset the router. Did a full cache clean on the pc browser. And disabled cloud fair. I can now get in.
Was something odd going on there somewhere.
@Jaywrk
Glad you got it sorted, would still be good to know if WiFi/Ethernet issue.
I do both laptop is always on WiFi as no physical port, but desktop is always
ethernet as it does not have any wireless capability.
Generally find that there is NEVER an issue getting in, timeout sometimes happens
but not always.....
Avatar for Jaywrk
Was strange. The pc is wired but most other things wireless.
