2
Discussion topic: Sky haven't turned up for two installation appointments. I m looking for a way to get a definite ap.
This message was authored by MichaelLogan This message was authored by: MichaelLogan
I've made several attempts to contact Sky to schedule an installation. The engineer didn't turn up for two previous appointments.
Calls to 03442 cannot be processed by Sky because I'm using an overseas mobile number. The installation is for UK address but Sky seem to be unable to process my installation.
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: Sky haven't turned up for two installation appointments. I m looking for a way to get a definite
@MichaelLogan no idea why you cannot call Sky's 03 numbers as these are standard UK non-geographic numbers charged at normal rates. They are accessible from outside the UK by addding the +44 prefix and dropping the leading zero. Most Sky numbers start 033 but be careful of numbers found on line as they can be call forwarding service aka rip off merchants.
Sky only do a limited number of broadband installs themselves most especially where new fibre lines are being run thst work is normally done by Openreach who do miss appointments as the engineers gave multiple appointments scheduled for a slot where one jib over runs the later jobs get dropped. Nothing either you or Sky can do unfortunstely. You will be compensated after the job is complete see Customer Auto-Compensation | Sky Help | Sky.com
MichaelLogan
Thanks for the information.
After posting that I made one more attempt to get through, and bingo!
Don't know what was different this time but got through to someone who could see what was wrong.
Installation visit scheduled for tomorrow.
Third time lucky 😀 hopefully.
