Discussion topic: Sky gone off
Message posted on 10 Oct 2025 08:28 PM
Sky gone off
Internet signal gone off several times in thdd Ed last half hour
Message posted on 10 Oct 2025 08:34 PM
Re: Sky gone off
@nj7903
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
