Discussion topic: Sky gigafast
Message posted on 15 Feb 2025 08:00 AM
Sky gigafast
Morning, would someone be able to tell me a compatible modem for sky giga fast to replace the current black one.
I believe my connection is via ONT on the wall and not the phone line, sorry not very tech....😊
Message posted on 15 Feb 2025 08:46 AM
Re: Sky gigafast
@Sabazios you have a full fibre connection if you have an ONT which effectively is the modem. You can connect a third party router to the ONT but if you are in the UK it is sensible to buy one that support DHCPv4 Option61 like the range from Asus. While routers that lack that support may connect using the alternative DHCPv6 PD method but that onlyworks on 80% of lines. Ireland is different.
Assume you know enough of how to configureca third party router although you will find wlk throughs on the forum for Asus and a few others in you sesrch. Note you will lose the Sky Talk land line if you use a third party router attached to the ONT. Sky will require you to reattach the Sky hub if you meed support with a line issue.
Message posted on 17 Feb 2025 06:35 AM
Re: Sky gigafast
Thank you 👍
