Discussion topic: Sky dowm
This message was authored by: Kingbthe1
Sky dowm
Sky keeps dropping and buffering since yesterday
Re: Sky dowm
@Kingbthe1
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
