Discussion topic: Sky causing issues on websites
Message posted on 03 Jul 2026 09:00 PM
Message posted on 04 Jul 2026 07:09 AM
Re: Sky causing issues on websites
@NLG it is higly unlikely that Sky are blocking access to Chat GPT as if they were the forum would have multiple reports and generally despite what some people believe ISPs like Sky dont block sitesxas its bad for business. You say you have disabled Sky's Broadbsnd Shield which is the only likely cause so check you have indeed done that see https://www.sky.com/help/articles/sky-broadband-shield-start
If you had "disabled DND" you would have no connection at all so not sure quite what you mean. All Sky hubs are hardwired to use Sky's DNS the only way to bypass thst would be to use something like a VPN which will have its own DNS service. However you can add a public DNS to your devices network settings. Google's at 8.8.8.8 and 8.8.4.4.is popular and fast. Unless you directly enter the IP address of a site DNS is essential.
Not sure what the cause of your issue is but it is very unlikely to be being directly caused by your Sky connection.
