Discussion topic: Sky broadband not working
Message posted on 13 Oct 2026 08:52 PM
My internet went down about an hour ago, on my router the internet light is off, and the voice light is amber. The other two lights are green.
can someone help me please?
Message posted on 13 Oct 2026 08:55 PM
Re: Sky broadband not working
@CathLogan
Use this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that only affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 13 Oct 2026 09:16 PM
Thanks Daniel - looks like there's a fault so engineer booked for tomorrow. Appreciate your prompt response
