Discussion topic: Sky broadband not working
Message posted on 08 Jun 2026 07:42 PM
Hello my sky router has a green light for power, orange for internet green for wifi and orange for voice. The sky service checker says everything is fine and working but I still get no service despite the wifi connecting to devices. Any ideas? Thanks
Message posted on 08 Jun 2026 07:44 PM
Re: Sky broadband not working
@BenSinden
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
Try running this line test to see if it finds any faults:
Message posted on 08 Jun 2026 07:50 PM
I've run the line test multiple times and it still thinks everything is ok. It has been down for roughly 1.5 hours now.
I should have said, I expect voice is always orange as I don't have a landline package.
I guess I will just have to wait for it to show in the service check or hope it resolves itself.
