Discussion topic: Sky broadband not working
Message posted on 28 Jan 2025 10:55 PM
No internet connection for the whole day
Message posted on 29 Jan 2025 01:26 AM
Re: Sky broadband not working
@Dennisbaah
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
