09 Sep 2024 02:08 PM
My Internet keeps going off
I reset tue power at the wall and it seems to work for an hour or so and then just goes off again
I've tried the network reset and turning it off at the wall
Any ideas please
09 Sep 2024 03:29 PM
Posted by a Superuser, not a Sky employee. Find out more@Luke58 What lights change on the router when this happens?
09 Sep 2024 03:57 PM
It's now just a single red light on power
But it has been changing all over the place
09 Sep 2024 03:59 PM
Posted by a Superuser, not a Sky employee. Find out more@Luke58 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
