Discussion topic: Sky broadband dropped
Message posted on 22 May 2025 10:09 PM
Message posted on 23 May 2025 04:48 AM
Re: Sky broadband dropped
@Diane2020
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
