Discussion topic: Sky broadband down
Message posted on 18 Nov 2025 03:30 PM
Sky broadband down
Is anyone in the So40 area experiencing phoneline outage causing broadband issues?
Message posted on 18 Nov 2025 03:39 PM
Re: Sky broadband down
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
