Discussion topic: Sky broadband down
Message posted on 02 Mar 2025 02:43 PM
Sky broadband down
My Sky Broadband is down and not working
Message posted on 02 Mar 2025 02:51 PM
Re: Sky broadband down
@Cozzergolf
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
