Discussion topic: Sky broadband down in Braintree for the last 24 hours. Not impressed
Message posted on 01 Aug 2024 05:57 AM
Sky broadband is down in Braintree for the last 24 hours. Not impressed at all. What is going on??
Message posted on 01 Aug 2024 06:15 AM
Re: Sky broadband down in Braintree for the last 24 hours. Not impressed
@Dani771 the connection test in the My Sky app will tell you if Sky are aware of an area issue affecting your line if you click to run the full test. If it doesnt call Sky and report the fault.
If it is an area issue it is highly unlikely Sky can give an accurate estimate of when it will be fixed as often the Ooenreach engineers doing the work wont know until the job is complete.
Message posted on 01 Aug 2024 07:10 AM
I'm also in Braintree, I believe it's not an area issue.. due to the fact when it checks the area it says it's all good.
will try and contact sky at 8am along with many others I'm sure!
Message posted on 01 Aug 2024 07:14 AM
I can't even do the test it's not working either. Keeps saying unavailable. 24 hours like this. Ridiculous now!
Message posted on 23 Oct 2024 07:18 AM
Mine went off just after 10pm last night, still off. App just says "outage in your area" and then stated it should be fixed in a couple of days!!!
Message posted on 23 Oct 2024 11:59 AM
I'm also in Braintree and it went down last night and was still off this morning. The check connection link on Sky just says everything ok, which it's not!
